Integration of AX 2009 with weigh bridge.
Can anybody please tell me how can we integrate weigh bridge machine with AX 2009 and what are the tools available for this ?
Is it possible to this or not? I just know that there are some classes in AX 2012 which helps in reading the data from ports but I think those classes are not available in Ax 2009?
Kindly help me in this as I am new to integration and I need to integrate weigh bridges with AX 2009.
Thanks and regards.
It depends on what interface is available to the machine. The easiest situation is if there is already some API, e.g. in COM or .NET.
If you need to use serial port or something directly, you should rather develop it in other language and encapsulate it in a .NET assembly or a COM object by yourself.
