When I try to integrate Microsoft Dynamics AX 2012 with external software called Scribe, it asks for the “AX Endpoint URL”. For that we can use default AX endpoint, I tried to find that URL. Finally end up in creating a service in System Administration-> Setup->Services and Application Integration Framework->Inbound ports, here I have created one service with Address Adapter “HTTP”.
Then, I gave the WSDL URI i.e., .svc service which I have created in the Inbound ports of Microsoft dynamics AX 2012, in the “AX endpoint URL” Then I got the errors:
Error opening data source Scribe.AXAdapter.AXDatabase.
System.Net.WebException: The remote server returned an error: (401) Unauthorized.
The HTTP request is unauthorized with client authentication scheme ‘Anonymous’. The authentication header received from the server was ‘Negotiate,NTLM’.
Stack trace:
System.ServiceModel.Security.MessageSecurityException: The HTTP request is unauthorized with client authentication scheme ‘Anonymous’. The authentication header received from the server was ‘Negotiate,NTLM’.
Server stack trace:
at System.ServiceModel.Security.IssuanceTokenProviderBase1.DoNegotiation(TimeSpan timeout)** **at System.ServiceModel.Security.SspiNegotiationTokenProvider.OnOpen(TimeSpan timeout)** **at System.ServiceModel.Security.WrapperSecurityCommunicationObject.OnOpen(TimeSpan timeout)** **at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)** **at System.ServiceModel.Security.CommunicationObjectSecurityTokenProvider.Open(TimeSpan timeout)** **at System.ServiceModel.Security.SymmetricSecurityProtocol.OnOpen(TimeSpan timeout)** **at System.ServiceModel.Security.WrapperSecurityCommunicationObject.OnOpen(TimeSpan timeout)** **at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)** **at System.ServiceModel.Channels.SecurityChannelFactory
1.ClientSecurityChannel1.OnOpen(TimeSpan timeout)** **at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)** **at System.ServiceModel.Security.SecuritySessionSecurityTokenProvider.DoOperation(SecuritySessionOperation operation, EndpointAddress target, Uri via, SecurityToken currentToken, TimeSpan timeout)** **at System.ServiceModel.Security.SecuritySessionSecurityTokenProvider.GetTokenCore(TimeSpan timeout)** **at System.IdentityModel.Selectors.SecurityTokenProvider.GetToken(TimeSpan timeout)** **at System.ServiceModel.Security.SecuritySessionClientSettings
1.ClientSecuritySessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOpenOnce.System.ServiceModel.Channels.ServiceChannel.ICallOnce.Call(ServiceChannel channel, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOnceManager.CallOnce(TimeSpan timeout, CallOnceManager cascade)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Scribe.AXAdapter.AXConnectivity.AxaptaService.IAxaptaService.Execute(String request)
at Scribe.AXAdapter.AXConnectivity.Axapta.AXGateway._ExecuteAXRequest[T](String request, AXExecutionResult`1& axExecutionResult, String errorMessage)
On Checking the event Viewer also, It doesn’t give any error information**.**
I have a doubt in the “AX Endpoint URL”, whether the URL that I have given is correct or any other default endpoint URL is there for AX 2012.
Thanks in advance,
Auxilia.
