Hello All,
I need a help on integrate VS 2008 (C#) with axapta 2009.
actually my requirement is to insert the data in axapta table through C# page…
if u have any thing on that or any readymade page then plz share with me or Send on
my email id : moazzam@octaware.com
Thanks in advance…
You need to use Business Connector for this. Get the book Inside Microsoft Dynamics Ax 2009 or tutorial development materials .
Thanks Friend,
But did u have any sample code for inserting data from c# page to axapta database.
If u have then plz share it …
my email id is moazzam@octaware.com
Thanks…
using Microsoft.Dynamics.BusinessConnectorNet;
// Create the .NET Business Connector objects.
Axapta ax;
AxaptaRecord axRecord;
string tableName = “AddressState”;
try
// Login to Microsoft Dynamics AX.
ax = new Axapta();
ax.Logon(null, null, null, null);
// Create a new AddressState table record.
using (axRecord = ax.CreateAxaptaRecord(tableName));
// Provide values for each of the AddressState record fields.
axRecord.set_Field(“NAME”, “MyState”);
axRecord.set_Field(“STATEID”, “MyState”);
axRecord.set_Field(“COUNTRYREGIONID”, “US”);
axRecord.set_Field(“INTRASTATCODE”, “”);
// Commit the record to the database.
axRecord.Insert();
catch (Exception e)
Console.WriteLine(“Error encountered: {0}”, e.Message);
// Take other error action as needed.
Source: http://msdn.microsoft.com/en-us/library/aa868997.aspx
