hi,
how to integrate the External databases to ur AOS?
hi,
Hi Murali,
First of all, please post in the right forums! Post NAV questions in the NAV forums and AX questions in the AX forums! Thanks. I assume you ask about AX (AOS). So the post will be moved there.
Second you might want to add a few more details to your questions. Integrating a database into any system can be done in many different ways, and which method to use often depends on exactly what the purpose of the integration is. Which system is the “parent” and which is the “child” if any? Is it a synchronization of data or just one system feeding another or or or? There are so many different ways to integrate and often relay you to use different methods.
