Instance not open
I have a practice instance it wasn’t open
the error is Connection with the Application Object Server could not be established
i searched in the server user permissions i am in the admin group…
please suggest to solve the solution
Check the Connection details in axapta configuration 2009 utility. May be it is wrong.
Hi Kishore,
This error may occurs due
Services are not started,check wither dynamcis ax services are started or not…
If not , Open the Client configuration utility there in the connection tab check the ‘Server Name’ , ‘Instance Name’ and the ‘Port Number’ are given correctly…
