Installing Report Manager for AX 2012
Hi guys,
Good day!
Someone knows how to install Report Manager in AX 2012? or if you could give/share the installation manual? because when we tried to install and configure the Report Manager, we got error messages.
Below are the error messages:
Error 1:
“The specified integration user credentials aren’t valid. Verify that the user name and password are correct and that the user is a member of the ‘db_datareader’ database role.”
Error 2:
“An unexpected error occured while attempting to connect to the ERP database. Check the configured database server and name. Details about the error can be found be found in your deployment log.”
Looking forward to hear from you guys.
AML
I think the problem is, you dont have the rights to SQL Server reporting server database.
open Sql server management studio, try to connect reporting server database.if you are not able to connect to reporting server database. connect with database engine → Security → logins. create new login and give the dbowner,and db writer rights to your login.
Hope it may works…
AML,
Here is link to documentation http://www.microsoft.com/en-us/download/details.aspx?id=5916
Did you find a solution? I am getting
error when trying to create a datamart. I know it is not a credential problem because the response time when invalid credentials are supplied is way longer. I saw GP uses were getting this error when they needed to run a clean company script. So I think with AX it is also a data issue; but don’t know what it could be.
Based on your post and the errors, I am guessing that you really are referring to Management Reporter. That is what the link is for, and I’m getting that same error message attempting to install the Management Reporter datamart.
