Hi, all, need your help.
I am trying to install Navision client via Active Directory (assigned to user) but have repeating issues.
We use Windows XP SP2 and DotNet 3.5 is already installed on machine
If I install manually with admin rights, using the following command:
msiexec /i “\mydomain\dfsroot\Software\Dynamix\Microsoft Dynamics NAV 5.0 SP1 CSIDE Client ru-RU.msi” /qb-
there’s no problem.
But if I assign the same application to user via GPO it goes bad.
User receives assigned shortcut, but when he double click installation begins and fails with the following event:
Event Type: Warning
Event Source: MsiInstaller
Event Category: None
Event ID: 1001
Date: 19.11.2009
Time: 11:00:47
User:
Computer:
Description:
Detection of product ‘{00000000-0000-5010-BA00-0000836BD2D2}’, feature ‘NavisionSolutions’ failed during request for component ‘{A752F994-382F-11D3-9F27-00A024A662C8}’
If he double clicks the shortcut again, everything is repeated.
Most strange, that all files and registry are installed and if i start finsql.exe, it works.
I also tried to assign installation package Microsoft Dynamics NAV 5.0 SP1 CSIDE Client en-RU.msi instead Microsoft Dynamics NAV 5.0 SP1 CSIDE Client ru-RU.msi, but it all the same, no luck.
Can anyone please advice on this ?
Thanks, Andy
