I have a customer running NAV 2.01 technical upgraded to a NAV 2009 on SQL. I am now about to install a NAV2016 to them and are wondering if there are any interference by installing the new version on the same server as the 2009-version is running?
Is there anything special I need to consider when doing this?
Hi Rebecca,
I would like to add that it is also now, in connection with an upgrade to Dynamics NAV 2016, that your client should consider upgrading their SQL.
If it’s a NAV 2009, then my guess is that it’s SQL 2008 or earlier. Typically that’s not something you would change that often, but doing it now is a good time. Especially if their SQL is older than 2008. But check the software requirements against both their servers and clients, as suggested by Saurav.
