Installing NAV 2015: error message build 37874
hi guys am installing NAv 2015 into a machine that had already installed Nav 2013 but am getting an error before completion… error message
’ Microsoft Dynamics NAV Build 37874
Error Report
Setup Components
An error occurred during insntallation
Can you confirm that .NET Framework 4.5.2 is installed on the machine? This used to be the main fault in my instances of this issue.
Link for download here: www.microsoft.com/.../details.aspx
thanks alot for your reply, but a.Net framework 4.5 is installed
What are you installing it onto?
Are you sure your permissions are ok?
Have you checked if there is anything in the detailed error log or event viewer?
