Hi guys!! i am looking for a easy procedure to know which are the hot fixes that have been installed in a MBS Navision 3.70… Can anyone help me?? [?] Regards and thanks!!
You’d have to know the version tags that were used in each improvement, and then search the version list of your database for those tags. Not finding a particular tag doesn’t mean that the improvement isnt in there though, it could have been upgraded again for a subsequent improvement. However, finding a newer tag than the one you’re looking for does NOT mean that the one before that one was implemented either. The only way to make sure is doing a text compare of the objects. So the short and simple answer is: There is not an easy procedure to do this.
