Installation Process
Hi Guys !!
How to install the AX in different components ie in Client, Server & Database ?? Not in stand alone system ??
I have another question ?
There are 2 AOS & 3 Databases for example AOS1, AOS2 & DB1, DB2, DB3.
Then how to connect or configure AOS1 to DB 3??
Thanks in advance !!
Hi Ullas,
You have to install component one after another in specific order. See here - http://technet.microsoft.com/en-us/library/dd362138.aspx
Database could be changed under from Admin tools > MS Dynamics Server configuration > Database Connection tab in AOS Server
