#### Hi guys, we are trying to install Enterprise Search (ES) but it is throwing an error at the end stating “An error occurred during setup of Enterprise Search”. All the prerequisites has been passed successfully.
Note: We have installed Help server & Enterprise Portal successfully.
Please help.### ### This is the setup log file.
=== Setup logging started: 23/01/2013 4:07:56 PM ===
Running file: “C:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe” RelatedFilesDir=“E:” AutoRun=1 LogDir=“C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-01-23 16-07-55”
AxSetup version number: 6.2.158.0
Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit)
HONIKEAX
NIKE\Administrator
Interactive: True
2013-01-23 16:07:56Z RelatedFilesDir=E:
2013-01-23 16:07:56Z LogDir=C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-01-23 16-07-55
2013-01-23 16:07:56Z Property RelatedFilesDir set to: ‘E:’
2013-01-23 16:07:56Z Property LogDir set to: ‘C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-01-23 16-07-55’
2013-01-23 16:07:56Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2013-01-23 16:07:56Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2013-01-23 16:07:56Z Initializing log file: C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-01-23 16-07-55\DynamicsSetupLog.txt
2013-01-23 16:07:56Z === Starting evaluation of existing installation state ===
2013-01-23 16:07:56Z Application Object Server instance 01 has been installed with the name 01-NIKEDB.
2013-01-23 16:07:56Z MSI file: Components64.msi Installed: True
2013-01-23 16:07:56Z MSI file: HelpServer64.msi Installed: True
2013-01-23 16:07:56Z MSI file: ClientOba64.msi Installed: True
2013-01-23 16:07:56Z MSI file: TraceParser.msi Installed: True
2013-01-23 16:07:56Z MSI file: RapidStartConnectorService.msi Installed: False
2013-01-23 16:07:56Z Previously Installed Component: Application Object Server (AOS) (01-NIKEDB)
2013-01-23 16:07:56Z Previously Installed Component: Web services on IIS
2013-01-23 16:07:56Z Previously Installed Component: Management utilities
2013-01-23 16:07:56Z Previously Installed Component: Enterprise Portal (EP)
2013-01-23 16:07:56Z Previously Installed Component: .NET Business Connector
2013-01-23 16:07:56Z Previously Installed Component: Debugger
2013-01-23 16:07:56Z Previously Installed Component: Visual Studio Tools
2013-01-23 16:07:56Z Property RunMode set to: ‘AddRemoveFeatures’
2013-01-23 16:07:56Z === Starting UI phase ===
2013-01-23 16:07:56Z S030WelcomeInfo
2013-01-23 16:08:00Z S040MaintenanceMode
2013-01-23 16:08:14Z Property RemoveComponents set to: ‘0’
2013-01-23 16:08:15Z S080FeatureOption
2013-01-23 16:08:16Z Property BypassWarnings set to: ‘0’
2013-01-23 16:08:19Z Property InstallSearch set to: ‘1’
2013-01-23 16:08:20Z Property ClientLanguage set to: ‘EN-US’
2013-01-23 16:08:20Z Property AosPort set to: ‘2712’
2013-01-23 16:08:20Z Property ClientAosServer set to: ‘HONIKEAX’
2013-01-23 16:08:21Z Property AosPort set to: ‘2712’
2013-01-23 16:08:21Z Property AosWsdlPort set to: ‘8101’
2013-01-23 16:08:21Z Property ClientAosServer set to: ‘NIKEDB@HONIKEAX’
2013-01-23 16:08:22Z S640InitialPrerequisites
2013-01-23 16:08:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRRESXMAP.xml’.
2013-01-23 16:08:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRPRCMAP.xml’.
2013-01-23 16:08:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRCAMAP.xml’.
2013-01-23 16:08:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPPRMAP.xml’.
2013-01-23 16:08:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPDATA.xml’.
2013-01-23 16:08:22Z Loading prerequisites for component ‘’:
2013-01-23 16:08:22Z Computer restart pending
2013-01-23 16:08:22Z Microsoft .NET Framework 3.5 Service Pack 1
2013-01-23 16:08:22Z Domain user account
2013-01-23 16:08:22Z Local administrator
2013-01-23 16:08:22Z Microsoft Windows Installer
2013-01-23 16:08:22Z Adding prerequisite ‘Computer restart pending’.
2013-01-23 16:08:22Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-01-23 16:08:22Z Adding prerequisite ‘Domain user account’.
2013-01-23 16:08:22Z Adding prerequisite ‘Local administrator’.
2013-01-23 16:08:22Z Adding prerequisite ‘Microsoft Windows Installer’.
2013-01-23 16:08:22Z Loading prerequisites for component ‘Enterprise Search’:
2013-01-23 16:08:22Z Server operating system
2013-01-23 16:08:22Z Business Data Connectivity (BDC) service application deployed
2013-01-23 16:08:22Z Microsoft .NET Framework 4.0
2013-01-23 16:08:22Z SharePoint Search
2013-01-23 16:08:22Z SharePoint Server Search service startup type
2013-01-23 16:08:22Z SharePoint Server Search service started
2013-01-23 16:08:22Z Microsoft SharePoint
2013-01-23 16:08:22Z Windows Identity Foundation
2013-01-23 16:08:22Z Adding prerequisite ‘Server operating system’.
2013-01-23 16:08:22Z Adding prerequisite ‘Business Data Connectivity (BDC) service application deployed’.
2013-01-23 16:08:22Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2013-01-23 16:08:22Z Adding prerequisite ‘SharePoint Search’.
2013-01-23 16:08:22Z Adding prerequisite ‘SharePoint Server Search service startup type’.
2013-01-23 16:08:22Z Adding prerequisite ‘SharePoint Server Search service started’.
2013-01-23 16:08:22Z Adding prerequisite ‘Microsoft SharePoint’.
2013-01-23 16:08:22Z Adding prerequisite ‘Windows Identity Foundation’.
2013-01-23 16:08:22Z E:\
2013-01-23 16:08:22Z Components selected:
2013-01-23 16:08:22Z Enterprise Search
2013-01-23 16:08:23Z Checking the following prerequisites:
2013-01-23 16:08:23Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2013-01-23 16:08:23Z Check succeeded.
2013-01-23 16:08:23Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-01-23 16:08:23Z Searching for a minimum version of ‘3.5.30729.1’.
2013-01-23 16:08:23Z Version found: ‘3.5.30729.5420’.
2013-01-23 16:08:23Z Performing a domain account check for prerequisite ‘Domain user account’.
2013-01-23 16:08:23Z Performing a local administrator check for prerequisite ‘Local administrator’.
2013-01-23 16:08:23Z Performing a windows installer version check for prerequisite ‘Microsoft Windows Installer’.
2013-01-23 16:08:23Z Searching for a minimum version of ‘3.0.0.0’.
2013-01-23 16:08:23Z Version found: ‘5.0.7601.17807’.
2013-01-23 16:08:23Z Performing an OS version check for prerequisite ‘Server operating system’.
2013-01-23 16:08:23Z Searching for a minimum version of ‘6.0.1.0’ and a suggested version of ‘6.0.1.0’.
2013-01-23 16:08:23Z Version found: ‘6.1.7601.0’.
2013-01-23 16:08:23Z Success
2013-01-23 16:08:23Z Performing a check to determine if Sharepoint BDC Search has been installed for prerequisite ‘Business Data Connectivity (BDC) service application deployed’.
2013-01-23 16:08:24Z Check succeeded.
2013-01-23 16:08:24Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.0’.
2013-01-23 16:08:24Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SoftWare\Microsoft\NET Framework Setup\NDP\v4\Full’.
2013-01-23 16:08:24Z Success
2013-01-23 16:08:24Z Searching for a minimum version of ‘4.0.30319.0’.
2013-01-23 16:08:24Z Version found: ‘4.0.30319.0’.
2013-01-23 16:08:24Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.0’.
2013-01-23 16:08:24Z Performing a service existence check for prerequisite ‘SharePoint Search’.
2013-01-23 16:08:24Z Checking for the existence of the service ‘OSearch’.
2013-01-23 16:08:24Z Performing a service status check for prerequisite ‘SharePoint Server Search service startup type’.
2013-01-23 16:08:24Z Checking the startup type of the service ‘OSearch14’.
2013-01-23 16:08:24Z Found: ‘Automatic’ Expected: ‘Automatic’.
2013-01-23 16:08:24Z Performing a service status check for prerequisite ‘SharePoint Server Search service started’.
2013-01-23 16:08:24Z Checking the status of the service ‘OSearch’.
2013-01-23 16:08:24Z Performing a registry key version check for prerequisite ‘Microsoft SharePoint’.
2013-01-23 16:08:24Z Searching for a minimum version of ‘14.0.0.0’.
2013-01-23 16:08:24Z Version found: ‘14.0.0.0’.
2013-01-23 16:08:33Z Property AosPort set to: ‘2712’
2013-01-23 16:08:33Z Property AosWsdlPort set to: ‘8101’
2013-01-23 16:08:33Z Property ClientAosServer set to: ‘NIKEDB@HONIKEAX’
2013-01-23 16:08:33Z S270BCProxyAccountEntry
2013-01-23 16:08:53Z Property BusinessConnectorProxyAccount set to: ‘NIKE\BCPROXY’
2013-01-23 16:08:53Z Property BusinessConnectorProxyAccountPassword set to: ‘**********’
2013-01-23 16:08:53Z Property HelpServerPhysicalDirectory set to: ‘C:\inetpub\wwwroot\DynamicsAX6HelpServer’
2013-01-23 16:08:53Z S271EPSearchAccountEntry
2013-01-23 16:09:21Z Property ContentAccessAccount set to: ‘NIKE\SCRAWLER’
2013-01-23 16:09:21Z Property ContentAccessAccountPassword set to: ‘**********’
2013-01-23 16:09:21Z Loading prerequisites for component ‘’:
2013-01-23 16:09:21Z Computer restart pending
2013-01-23 16:09:21Z Microsoft .NET Framework 3.5 Service Pack 1
2013-01-23 16:09:21Z Domain user account
2013-01-23 16:09:21Z Local administrator
2013-01-23 16:09:21Z Microsoft Windows Installer
2013-01-23 16:09:21Z Adding prerequisite ‘Computer restart pending’.
2013-01-23 16:09:21Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-01-23 16:09:21Z Adding prerequisite ‘Domain user account’.
2013-01-23 16:09:21Z Adding prerequisite ‘Local administrator’.
2013-01-23 16:09:21Z Adding prerequisite ‘Microsoft Windows Installer’.
2013-01-23 16:09:21Z Loading prerequisites for component ‘Enterprise Search’:
2013-01-23 16:09:21Z Server operating system
2013-01-23 16:09:21Z Application Object Server (AOS) Services WSDL URI accessible
2013-01-23 16:09:21Z Business Data Connectivity (BDC) service application deployed
2013-01-23 16:09:21Z Microsoft .NET Framework 4.0
2013-01-23 16:09:21Z SharePoint Search
2013-01-23 16:09:21Z SharePoint Server Search service startup type
2013-01-23 16:09:21Z SharePoint Server Search service started
2013-01-23 16:09:21Z Microsoft SharePoint
2013-01-23 16:09:22Z Windows Identity Foundation
2013-01-23 16:09:22Z Adding prerequisite ‘Server operating system’.
2013-01-23 16:09:22Z Adding prerequisite ‘Application Object Server (AOS) Services WSDL URI accessible’.
2013-01-23 16:09:22Z Adding prerequisite ‘Business Data Connectivity (BDC) service application deployed’.
2013-01-23 16:09:22Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2013-01-23 16:09:22Z Adding prerequisite ‘SharePoint Search’.
2013-01-23 16:09:22Z Adding prerequisite ‘SharePoint Server Search service startup type’.
2013-01-23 16:09:22Z Adding prerequisite ‘SharePoint Server Search service started’.
2013-01-23 16:09:22Z Adding prerequisite ‘Microsoft SharePoint’.
2013-01-23 16:09:22Z Adding prerequisite ‘Windows Identity Foundation’.
2013-01-23 16:09:22Z S630Prerequisites
2013-01-23 16:09:22Z E:\
2013-01-23 16:09:22Z Components selected:
2013-01-23 16:09:22Z Enterprise Search
2013-01-23 16:09:22Z Loading prerequisites for component ‘’:
2013-01-23 16:09:22Z Computer restart pending
2013-01-23 16:09:22Z Microsoft .NET Framework 3.5 Service Pack 1
2013-01-23 16:09:22Z Domain user account
2013-01-23 16:09:22Z Local administrator
2013-01-23 16:09:22Z Microsoft Windows Installer
2013-01-23 16:09:22Z Adding prerequisite ‘Computer restart pending’.
2013-01-23 16:09:22Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-01-23 16:09:22Z Adding prerequisite ‘Domain user account’.
2013-01-23 16:09:22Z Adding prerequisite ‘Local administrator’.
2013-01-23 16:09:22Z Adding prerequisite ‘Microsoft Windows Installer’.
2013-01-23 16:09:22Z Loading prerequisites for component ‘Enterprise Search’:
2013-01-23 16:09:22Z Server operating system
2013-01-23 16:09:22Z Application Object Server (AOS) Services WSDL URI accessible
2013-01-23 16:09:22Z Business Data Connectivity (BDC) service application deployed
2013-01-23 16:09:22Z Microsoft .NET Framework 4.0
2013-01-23 16:09:22Z SharePoint Search
2013-01-23 16:09:22Z SharePoint Server Search service startup type
2013-01-23 16:09:22Z SharePoint Server Search service started
2013-01-23 16:09:22Z Microsoft SharePoint
2013-01-23 16:09:22Z Checking the following prerequisites:
2013-01-23 16:09:22Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2013-01-23 16:09:22Z Check succeeded.
2013-01-23 16:09:22Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-01-23 16:09:22Z Searching for a minimum version of ‘3.5.30729.1’.
2013-01-23 16:09:22Z Version found: ‘3.5.30729.5420’.
2013-01-23 16:09:23Z Performing a domain account check for prerequisite ‘Domain user account’.
2013-01-23 16:09:23Z Check succeeded.
2013-01-23 16:09:23Z Performing a local administrator check for prerequisite ‘Local administrator’.
2013-01-23 16:09:23Z Performing a windows installer version check for prerequisite ‘Microsoft Windows Installer’.
2013-01-23 16:09:23Z Searching for a minimum version of ‘3.0.0.0’.
2013-01-23 16:09:23Z Version found: ‘5.0.7601.17807’.
2013-01-23 16:09:23Z Performing an OS version check for prerequisite ‘Server operating system’.
2013-01-23 16:09:23Z Searching for a minimum version of ‘6.0.1.0’ and a suggested version of ‘6.0.1.0’.
2013-01-23 16:09:23Z Version found: ‘6.1.7601.0’.
2013-01-23 16:09:23Z Success
2013-01-23 16:09:23Z Performing a service status check for prerequisite ‘Application Object Server (AOS) Services WSDL URI accessible’.
2013-01-23 16:09:25Z Check succeeded.
2013-01-23 16:09:25Z Performing a check to determine if Sharepoint BDC Search has been installed for prerequisite ‘Business Data Connectivity (BDC) service application deployed’.
2013-01-23 16:09:25Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.0’.
2013-01-23 16:09:25Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SoftWare\Microsoft\NET Framework Setup\NDP\v4\Full’.
2013-01-23 16:09:25Z Success
2013-01-23 16:09:25Z Searching for a minimum version of ‘4.0.30319.0’.
2013-01-23 16:09:25Z Version found: ‘4.0.30319.0’.
2013-01-23 16:09:25Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.0’.
2013-01-23 16:09:25Z Performing a service existence check for prerequisite ‘SharePoint Search’.
2013-01-23 16:09:25Z Checking for the existence of the service ‘OSearch’.
2013-01-23 16:09:25Z Performing a service status check for prerequisite ‘SharePoint Server Search service startup type’.
2013-01-23 16:09:25Z Checking the startup type of the service ‘OSearch14’.
2013-01-23 16:09:25Z Found: ‘Automatic’ Expected: ‘Automatic’.
2013-01-23 16:09:25Z Performing a service status check for prerequisite ‘SharePoint Server Search service started’.
2013-01-23 16:09:25Z Checking the status of the service ‘OSearch’.
2013-01-23 16:09:25Z Performing a registry key version check for prerequisite ‘Microsoft SharePoint’.
2013-01-23 16:09:25Z Searching for a minimum version of ‘14.0.0.0’.
2013-01-23 16:09:25Z Version found: ‘14.0.0.0’.
2013-01-23 16:09:25Z Adding prerequisite ‘Computer restart pending’.
2013-01-23 16:09:25Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-01-23 16:09:25Z Adding prerequisite ‘Domain user account’.
2013-01-23 16:09:25Z Adding prerequisite ‘Local administrator’.
2013-01-23 16:09:25Z Adding prerequisite ‘Microsoft Windows Installer’.
2013-01-23 16:09:25Z Adding prerequisite ‘Server operating system’.
2013-01-23 16:09:25Z Adding prerequisite ‘Application Object Server (AOS) Services WSDL URI accessible’.
2013-01-23 16:09:25Z Adding prerequisite ‘Business Data Connectivity (BDC) service application deployed’.
2013-01-23 16:09:25Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2013-01-23 16:09:25Z Adding prerequisite ‘SharePoint Search’.
2013-01-23 16:09:25Z Adding prerequisite ‘SharePoint Server Search service startup type’.
2013-01-23 16:09:25Z Adding prerequisite ‘SharePoint Server Search service started’.
2013-01-23 16:09:25Z Adding prerequisite ‘Microsoft SharePoint’.
2013-01-23 16:09:25Z Adding prerequisite ‘Windows Identity Foundation’.
2013-01-23 16:09:26Z S240LastInfo
2013-01-23 16:09:27Z S250InstallProgressInfo
2013-01-23 16:09:27Z === Starting execution phase ===
2013-01-23 16:09:27Z Executing ‘Enterprise Search’ this pass.
2013-01-23 16:09:27Z Enterprise Search
2013-01-23 16:09:27Z Queueing for installation: Components
2013-01-23 16:09:27Z Component installation task completed successfully.
2013-01-23 16:09:27Z === Setting up Components ===
2013-01-23 16:09:27Z Checking the following prerequisites:
2013-01-23 16:09:27Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2013-01-23 16:09:27Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2013-01-23 16:09:29Z Running Msiexec.exe with these parms: /i “E:\MSI\Components64\Components64.msi” /qb! /l*v “C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-01-23 16-07-55\Components64 Log.txt” DIRECTEXECUTE=1 /norestart INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\60” INSTALLDIR32=“C:\Program Files (x86)\Microsoft Dynamics AX\60” ADDLOCAL=“AifWebServices,EnterprisePortal,EPSearch,NetBusinessConnector,Debugger,EnterprisePortalTools,ReportingTools,ModelManagement,ClientConfig”
2013-01-23 16:09:29Z Running synchronously.
2013-01-23 16:12:27Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2013-01-23 16:12:27Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2013-01-23 16:12:27Z === Applying Updates to components ====
2013-01-23 16:12:27Z Searching for updates…
2013-01-23 16:12:38Z No applicable updates were found.
2013-01-23 16:12:39Z Checking if Client SDK call to generate WCF configuration is required …
2013-01-23 16:12:39Z Skipping call to client SDK API. WCF settings already present in the registry.
2013-01-23 16:12:39Z Client SDK Call done.
2013-01-23 16:12:39Z Post install for EP Search
2013-01-23 16:12:39Z Entering function PerformPostInstallActionsEPSearch
2013-01-23
