I’m trying to find the right way to install the new version of NAS SP1 on a server where there is already the NAS SP0 (initial version since 2 year). I understood that i have to copy the current directories for future uses and once done, remove the NAS version via the MSI file. Once done, i have to install the NAS SP1 and to ‘reactivate’ the old version copied in another directories.
Just let me kno if it’s the right way before to start the install;
Hi Dan, Our partner provides a solution with NAS SP0 two year ago and for the roll out in a new country, they migrated their solution to NAV and NAS SP1.
That’s the reason of the instalaltion of SP1 without removing the previous version.
Last question: If i remove the first.5.0 NAS, I should be able to ‘restore’ it from the copy. And i assume that the directory of NAS SP1 should be different from 5.0 NAS, right?
Hi DenSter, You’re right. The first Nav databases were based on 5.0 Nav and the new one is based on 5.0 NAV SP1. This explains the reason of the NAS SP1.
I run the install without problem, except that i need to reinstall the previous 5.0 NAS as it was the first install and the remove process deinstall the related service. But it’s not an issue. All works well until now.
Oh ok, the topic says “NAS server with version 5.00 and 5.00 SP1 on same server” so for a moment there I thought you had two instances of NAS installed at the same time, each with a different version, and both are connecting to the same database.
