How to install EP for Ax 2012 and how to configure(http://technet.microsoft.com/en-us/library/aa496457.aspx)
i am following technet,microsoft.com
but i am unable to understand that
The link you provided is upgrade guide.
Correct link to DAX 2012 installation guide here - http://technet.microsoft.com/en-us/library/dd362138.aspx
Hi harish,
Did you check that link …?
that’s also same path
I am getting
Thursday, February 23, 2012 3:56 PM
Developer Installation
Components Installed
Enterprise Portal (EP)
Details
An error occurred during setup of Enterprise Portal (EP) at http://dynamics/sites/DynamicsAx
The following error/warning occurred:Setup encountered an error during deployment of the Role Center and Enterprise Portal framework. Entering method deployEPOnSharepoint Deploying Static files… MergeNestedMasterPages:Success DeployStaticFiles:Success Deploying Static files…Complete Deploying Web Controls… \Web\Web Files\Web Controls - success Deploying Web Controls…Complete Deploying All Web Parts… Updating web.config file … Processing the Web server configuration file: D:\Program Files\Microsoft Dynamics CRM\CRMWeb\web.config Processing the Web server configuration file: D:\Program Files\Microsoft Dynamics CRM\CRMWeb\web.config Cannot install Enterprise Portal due to a conflict with the following settings in the web.config file that will prevent reports from running: Cannot install Enterprise Portal due to a conflict with the following settings in the web.config file that will prevent reports from running:
Log file location:D:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-02-23 15-40-14\DynamicsSetupLog.txt
