Inserting Values from keyboard ?
Is it possible in axapta to insert a value from keyboard and perform the calculations based on the provided value .
For ex :
I have been given a job to calculate the compound interest and by inserting the values of principal , year , rate , number etc manually from keyboard . Is this even possible in job ??
Yes, have a look at the Dialog classes. They create forms at runtime, where the user can input data such as the one you need.
https://msdn.microsoft.com/en-us/library/aa877843.aspx
Is there any possible way by which i don’t have to create any tables or forms .
Simply writing a job in such a manner that it takes two values from the users ??
Just read the link I provided to you. You can use the Dialog class in a job to prompt for user input. The input can be stored in variables, so you don’t need a table.
