INSERTING RECORDS
i have a table named “tasks” with some records,say 5 records. i want to view all these 5 records,in the Employee master against each employee in a seperate tab in the Employee master form. how to insert the records for each employee? i dont want to run through job,coz when a new employee is added the list of tasks from the task table should be added to the new employee.
One way is to override the Insert Method of the EmplTable.
Hai Raji,
Declare global method on employee form to insert the records to empltable from tasktable using while loop and call it by overriding modified method of emplid of form_ds
