Inserting new Unit of Measure
No, when you are using GET meaning you are passing the primary key fields as parameter. table “Item Unit Measure” has a primary key of “Item No.”,Code. So when you trying to get the Item UOM, you need to to pass item no. and the current UOM you are trying to create.
