I have a fairly simple form with a grid on it. The data source for the form is an AOT query. That query has one main table (table A) and two joined tables (tables B and C). The data source property for the grid is set to table A.
The purpose of the form is to display table A, with a couple of fields pulled from tables B and C for reference, and allow the user to edit table A and insert & delete records in table A.
This works fine, except that trying to do an insert from the grid appears to be trying to insert a new record into table B, in addition to table A. (I have verified this by putting a breakpoint in the validateWrite() method on table B.)
I’m not sure if I should even be able to do this or not. Does anyone have a clue what I might be missing here? Do I need to change something in the query, or on the form? Deleting, by the way, works fine: the record will be deleted from table A, and the records in table B & C are left alone.
Thanks in advance for any help!
