Hello Guys,
I want to Insert 10 records in a single field while opening a form
like in “Field1” want to insert Records
1st Record - Test1,
Test2,
Test3,…Test10
Thank in Advance.
Hello Guys,
1st Record - Test1,
Test2,
Test3,…Test10
Thank in Advance.
very strange question
Not every question is a silly question.Please try this to insert in table and while fetching in form in the init method write it as Conpeek(container,value) and read those values.
static void Job1(Args _args)
CustTable Cust;
table1 tab1;
int i;
container con;
While select cust
while(i <= 10)
i++;
tab1.Field2 = conIns(tab1.Field2,i,cust.AccountNum);
tab1.insert();
I would personally use a map to do this.
Map mapOfRecords = new Map(typesId2Type(typeId(recId)), Types::Record);
// To fill
mapOfRecords.insert(yourRecordObject.RecId, yourRecordObject);
// Then to store in a container
whatever.field1 = mapOfRecords.pack();
// To access later on in code
Map myNewMap = Map::create(whatever.field1);
// To iterate a map and use it
// http://msdn.microsoft.com/en-us/library/aa891324(v=ax.50).aspx
