Hi, I have a Navision 3.6 database ( not Sql server ). There is a need to connect this navision database to a Sql Server 7.0 database and insert data from Sql Server table(tablename SqlData1) into Navision database table( tablename NavisionData ) after every 5 min. What is the best way to do it? Thanks, Meenakshi (P.S. In this case, user doesn’t want to use dataports.)
Well… the best way to do it is telling your customer to contact us at Western Computer for doing it… [:P]… but you can also use an automation on the ADO for connecting to the sql server and retrieving the data… it’s up to you [;)] Regards,
Some sample code will be helpful, if anyone is willing to share[:)] Is there any specific automation ( for ADO) for version 7.0 of sql server or it doesn’t matter?
For the automation… check on your navision custom controls the Microsoft ADO Data control… I think there were a couple of samples on how to use that automation in previous posts…
NameDataType Subtype ADO_Connection Automation ‘Microsoft ActiveX Data Objects 2.7 Library’.Connection ADO_RecordSet Automation ‘Microsoft ActiveX Data Objects 2.7 Library’.Recordset NewItem Record Newitem ------------------------------------------ CREATE(ADO_Connection); ADO_Connection.Open(‘Provider=sqloledb;Data Source=SERVERNAME;Initial Catalog=DATABASENAME’,‘USERID’,‘PASSWORD’); CREATE(ADO_RecordSet); ADO_RecordSet.Open(‘TABLENAME’, ADO_Connection,1,3); IF NOT ADO_RecordSet.EOF THEN ADO_RecordSet.MoveFirst; IF NOT ADO_RecordSet.EOF THEN REPEAT IF NewItem.GET(ADO_RecordSet.Fields().Item(‘ItemNo’).Value) THEN BEGIN NewItem.Description := ADO_RecordSet.Fields().Item(‘Description’).Value; NewItem.MODIFY(TRUE); END ELSE BEGIN NewItem.“No.” := ADO_RecordSet.Fields().Item(‘Itemno’).Value; NewItem.Description := ADO_RecordSet.Fields().Item(‘Description’).Value; NewItem.INSERT(TRUE); END; ADO_RecordSet.MoveNext; UNTIL ADO_RecordSet.EOF; ADO_Connection.Close; CLEAR(ADO_RecordSet); CLEAR(ADO_Connection);
Thanks. This is very helpful.
In this above code the Item no is specify for what, please clear me .
Jai
