innvoice num repeating
presently iam a fresher i cant able to do one task in which the cst amount of particular invoice number is repeating in the next invoice num i have checked it in c/al coding too but it is not working plzzzz help me
Welcome to DUG!!!
What you are trying to do ? Is it report or are you trying to customizes some process?
Is it RTC or Classic?
What is version of Navision
in classic while ruunning the report it is showing the correct value for the invoice num but in RTC the value is printed as the above invoice num value for example Invoice no:n12/0189 CSTvalue is -323 in invoice no:n12/0190 CSTvalue 323 is coming instead off 798 and iam using 2009version plzzz kindly help me
What is the report ID?
Is report customized?
report id is 50062 and i didnt customized in it the issue is the value is repeating twice from other invoice number
50062 is not standard report.
It is developed by someone in your company…
Please contact partner…
Check in the report if the CST value is set to zero or not.
IN RTC how you are displaying the value ??
in rtc while checking it with the particular invoice number it is showing the correct value while printing the whole report the value is coming from the other invboice number
no sir CST value is not set to 0
it is given like this
IF CSTAmnt <>0 THEN
DiffTaxAmtCST := CSTAmnt - CrTaxAmt;
Initialize the variable before using it.
sorry sir i didnt understood
What u didn’t understood ?
You need to set variable value to zero before using it in program so when program runs through you code it will always make the value to zero so you will get correct value.
DiffTaxAmtCST := 0;
IF CSTAmnt <>0 THEN
thank u sir its working
Welcome [:)]
would be good if you verify the post that helped you out.
