I have created one lookup metod which uses query to fill combobox. but i want to initilise this grid line with first value in result of lookup query plz share your ideas
Thank You.
Thank You.
Can you explain in detail???
Are you asking for filtering of lookup based on the some other values - if that is the case use queryBuildRange in your lookup method.
