Hi Everyone!
I just want to ask, how long does it take (exact/approximate number of hours) if you start ‘Compile the application’ and ‘Compile into .NET Framework CIL’?
Thanks in advance.
Hi Everyone!
Thanks in advance.
Hi Russel,
It depends on the RAM … if you run the Compile App in server … normally it takes 12hrs. but if you run the Compile App on your workstation it takes 1day depending on the RAM, Processor, and Network …
Good Luck,
Paul
Hi Paul,
Thanks for the answer. Actually, I am running it through a virtual machine. I started the compilation of .NET Framework CIL at around 10am (PH time) until now it is currently compiling and the window says it is not responding. I wonder how long will it take to finish.
Again, thank you
Looking into night build logs of my current client, the latest build took:
X++: 2h 40 min
CIL: 11 min
DB synchronization: 9 min
But it really depends on your system. X++ compilation on my local DEV machine takes ~20 minutes, but it’s using AxBuild.exe and have plenty of resources.
