I need information about the form “POS Menu Grid” which was available in Nav 2009 version. Where it was used in Navision, and in updated versions the object was removed. So, where we can find the related code.
Thanks.
Thanks.
Ok got Information, The Form “POS Menu Grid” contains data to display rows and columns when we press the menu button (Example: Item Lookup).
In the Later Version, the code was moved into Code unit: 99001565 “POS DataSet Utility”.
Thank You.
