Has anyone tried using this tool? When I try to import the industry mapping sheet into Navision - I can’t find the screen they show in the documentation. Do you need special permissions to access? In the documentation it says to go under the setup checklist/functions/implementation. When I go under the setup checklist/functions I see a wizard but I don’t see implementation. This looks like a great idea if it works. Thanks for any help in advance.
Hi, I tried for version 3.7, but not from menu. I directly run the form from Object Designer.
