Indirect cost not available (Project category)
Finance has asked that I separate overhead cost to a differant account when using labor lines. There appears to be a way to do this natively using indirect costs:
https://community.dynamics.com/ax/b/axsupport/archive/2014/07/31/project-indirect-cost-components-in-ax-2012
But the indirect cost components are not available to us (2012 R2 CU0)1373.6-29-2015 10-28-52 AM.png
This screenshot is from an Admin account. Do we require an update or add-on to use this?
Can you check if you have the Indirect cost configuration under project3 and is enabled or not?
I do not:
You need to check in the License configuration.
System Administration → Setup → Licensing → License configuration
Expand Project 3 and see if you have indirect cost and if it is enabled (marked).
Project III is not even on the list. We have I and II. Thanks for the help, looks like we need some licence work.
