Indian Localization not getting install
hello everyone
I am trying to fresh installation of ax 2009. I done installation of basic setup then i install sp1 and then install indian localization and then install rollup 6. when i start ax server and then initialize all steps then also there is no indian localization is installed.
one more thing when i install indian localization that time there is only component check box is enabled. Application file’s check box is disable.
pls suggest
thanks in advance
How can you say that it is not installed? What are sequence of steps you have followed?
Well i check in like this Ax->menu->Help->About microsoft dynamics ax
on above location it will show which version and Localization is installed.
well I mention all steps in main post
hello Kranthi
i attached images which i done
first is image is when i doing installation of indian localization then only one check box is enabled 6011.GLS.bmp (977 KB)
then when i see version after rollup 6 it should be show like following
but it showing like this
