Increase The Speed Of Microsoft Dynamics 2012
I’m Running VPC (Microsoft Dynamics 2012) in 16GB Ram machine. I’ve optimized the configuration performance and still my dynamics 2012 is slow.
Is there any way I could increase the performance of the MSFT Dynamics 2012 through deleting some junk files in Virtual machine or In Dynamics backup files.
It all depends on what’s the performance problem. If you have very slow disk, for example, no configuration can change that.
If you believe that the problem is in virtualization, follow the advice in How to set up a Hyper-V server and make it perform section of Microsoft Dynamics AX 2012 Hyper-V Benchmark Detail.
It’s unlikely that you would improve performance by removing backup files or so. Rather concentrate on running processes and performance of SQL Server.
