increase the size (width) of Lookup Field
hi
Friends i want to increase the width of lookUp field (Drop Down field ) in form . please help me to do that…
thanking you
i am also suffering with same issue… instead of that i increased control lookup like i need lookup on dialog control
i just use as
control dialogPurchId;
dialogPurchid.width(30) ;
You can also have a look at the extended data Type’s display width property of your lookup field
Hope it helps, plaese verify solution if it solves your problem
regards,
Thomas
