How to increase the field Length, that field already extended from EDT. Now have to increase the field length. which process have to follow
Create a new EDT or update the existing EDT.
Tell us about the business reason.
ClientReference is the fieldname. It has extended from EDT but need to increase the size in two tables and one form and in document service. can create a new EDT for this is fine or anything to do.?
what about the other tables where it references? Why only in two tables?
You need to refresh the services so that the schema will be updated.
it is requirement have increase the size in 2 tables. Remain are to be same no need of increasing
Its OK, if it doesn’t impacts your data integrity.
