Incorrect date on Remittance Advice (GB only)
Hello, We have found an issue with the Remittance Advice reports (10531 -Remittance Advice - Journal and 10532 Remittance Advice - Entries) in the GB versions of Navision Financials 1.30 to 2.60. The remittance reports display the Document Date of the documents that have been paid on the Payment Journal, however, the actual field value displayed is the Posting date, not the Document Date. This appears to have been wrong from 1.30, when the reports were originally introduced to GB2.60G. This can be corrected by changing the source expression. 10531 - (Remittance Advice - Journal) does, however, work in Attain. This appears to be because it was entirely re-worked due to the major changes in Attain, but 10532 Remittance Advice - Entries is still incorrect.
