In which form method we can use Form_DS.getPosition() method....?
Hello All
I want to get the current position before executing the Form_DS.doResearch() using the “getPosition()”
and I want set the position to previous filtered position using “setPosition()”
Thanks In Advance…
you simply put Form_DS.getPosition() at the beginning of the method where you execute Form_DS.doResearch() and set the position after Form_DS.doResearch()
you can use this on button clicked event. You can also use From_DS.Research(true), the true parameters keep focus on the current position.
Hope it helps
Regards
Thomas
Hi Thomas,
Thanks for your quick response, the Form_DS.doResearch() is calling from a class
I tried to put getPosition() before the doResearch() and setPosition() aftet the doReserch()
It doesn’t worked for me…
Thanks In advance
Hi ,
use this type of code to get the correct record after research ,It is working for me
void Refresh()
vacationSettlement _vacSettlement;
int64 Recid;
VacationSettlement_1_ds.reread();
_vacSettlement = VacationSettlement_1_ds.cursor();
Recid = _vacSettlement.RecId;
_vacSettlement = vacationSettlement::findByRecId(recId);
VacationSettlement_1_ds.research();
VacationSettlement_1_ds.findRecord(_vacSettlement);
