Hi All When i have Generateing report iln my 1 salesorder have more then 2 lines But I got print in report frist line only how can sovle this problema any hekp me
Hi ,
Did u taken SalesTable and SalesLine tables in datasource node or u r sending the datasource through the fetch method.?
If u r using datasources in datasource node the make the relations property of saleLine into yes .And set that ur line body’s (In design -->body ) datasource property to 'SalesLine ’
If u r sending the datasource in fetch method then make sure to send as
while select SalesLine where SalesLine.SalesId == SalesTable.SalesId
element.send(SalesLine);
And set the line body’s(In design) datasource property to 'SalesLine ’
