In Navision 2009 How to insert data from one table to another
hai friends
anyone can pls explain How to insert data from one table to another …? Im New In Navison I know SQL server Triggers, Stored Procedure, and pls explain different types of Table triggers in Navision
Thanks In advance
SQL server triuggers, SP’s… WOW.
I suggest you start with the Application Designers Guide (ADG), or something from MSDN… but don’t start with SQL… Start with C/Side (C/AL)
t
Yep, if you have to code something for Navision in SQL, something is probably wrong. SQL is good for data…not so good for all the business logic necessary for Navision.
