Hi ,
I am trying to add one composite entity along with single entities in a single processing group.
while I am trying to generate mappings for composite entity it gives me following error :
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.IndexOutOfRangeException: Index was outside the bounds of the array.
at System.Array.InternalGetReference(Void* elemRef, Int32 rank, Int32* pIndices)
at System.Array.SetValue(Object value, Int32 index)
— End of inner exception stack trace —
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
