When i am browsing EP website the default page throws the below error.Even in Ax rich client also am getting the same error.
Source: Microsoft.Dynamics.AX.ManagedInterop
Exception details:
Data record not found
at Microsoft.Dynamics.AX.ManagedInterop.Record.CallWithReturnType(String methodName, Type returnType, Object[] paramList)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsRecordAdapter.Call(String methodName)
Following steps are already done but still same error
1.iisreset
2.Restarted AOS
3.Client config->BC Config->Config services and refresh and Business Connector is pointing to correct AOS
4.Restarted the AOS service
5.Admin->Enterprise Portal->Deployed Websites,Web Application and Server
6.Generated Incremental CIL
7.Refresh AOD,Data Dictionary and data.
8.Imported the EPDefaultRoleCenter url menu item and Deployed the page definition.
