hi ,
i am trying to create purchline through code for existing po ,
for this i am increment the line number with “10”,
because this is the unquie and index field so that i am able to create lines for the purchase order
through purchcreateline(false,false,false);
is this wrte way to create ???
if any body knows please help me
thanks
srikanth
Hi , I also want to confirm the same and one more question
When i am using purchline . createline() method i only get Item id , item unit , and item quantity and other assigned values cannot be reflected like purch price etc…
If any body knows please help…
hi ajay ,
u can add how many line u want by simple code
purchline.createline(true,false,true);
purchline…clear();
and answer for second question u cannot get the purchprice
Hi Srikanth,
First of thanks for posting on query…
I got one solution regarding the insertion of purchprice in purchlineTable i.e. rather than using purchline.createlines() method
I am directly inserting the record using purchLine.insert () and the requirement got fulfilled … but i want to know that is this the correct way to do this…
hi,
as per my knowledge it is not correct , some time u will face an error record already exist , if u uses the direct purchline,insert()
method,
thanks,
srikanth
