In a parameters form When I click new, system brings the first option of the look up. This should be empty while we select new.
My form is having New and delete command buttons, when i click new new. it will create a record with two fields “Stage and Status”/
my requirement is it should bring empty lookup when i click new instead it is getting all the previous values stored in lookup. how to approach.
stage field is an enum field.
Try to remove the data source value in the properties of the enum field.
Please check and verify the answer if found useful.
Bharath K
then all the value which are stored earlier are showing blank and when i enter any value in that field, how will it stored in the table ?
Up to my understanding by this line, I think I have found the solution for you.
Please explain in detail, If I have wrongly understood you.
