Hi All
I am exporting the Trail balance custom defined under General Ledger/Reports/Transaction/Periodics/Financial statement. This is already defined in one system. Now I am trying to export the Statement(template) it is how showing the following error when i am clicking the OK button:
“Row definition BS contains elements with fixed priority. Export canceled”
thanks
I think it will not allow you to export the row definition if there is an “element” type in your row.
Best Regards,
Carol
After deleting the elements, when i am trying to import the file, it is showing the following error:
“Cannot create a record in Row structure lines (LedgerRowDefLine).
Insert operations are not allowed across companies. Please use changecompany keyword to change the current company before inserting the record.”
Can you tell me how i can export the structure and import it into the new company.
