While I am importing a Xpo file, I am getting an error message i.e., The Value ‘no’ is not found in the map.
I selected
Application object and lables from import
Import with Id Values from options. can anyone share your ideas how to import
shon4z
2
uncheck… Import with id values!! and try
shon4z
4
I guess u are importing the xpo file from differnt version coz the error indicates that the particular object doesnt exist .
What are type of objects you are trying to import.?>>?
vardhan
5
Maximum toatal aot which is in ax 4.0, how can i do now
Ginmur
6
When you import with “Only application objects” it is the same?
From what/to AX version/SP are you exporting/importing? Are source and target AX the same versions (but this shuldbn’t be a big issue)?
