Importing e-mails in Nav 5.0
Hi
Does somebody know if it is possible to import e-mails (incoming & outgoing) in navision without having to save them first? In fact, I would like to be able to directly select an e-mail an automatically import it in navision.
Any idea?
grtz
Hi grtz,
Have you found an answer or solved your problem?
If yes, then I would hope that you would share the solution with the rest of the user group as I think many members would get value from the answer, so that we can close the topic and mark it as Answered.
If no, then maybe you can add a bit more information to the question, so that other members maybe are able to answer your question.
Thank you.
