I’m having a problem importing data via excel to AX. These are the steps I took:
1- I created an Excel Template by using the Template Wizard (Administration).
2- I copied my data from a SQL query to the Excel workbook (Excel Template Generated in step 1)
3- I went back to AX 2009, clicked on the Definition Groups and imported the data.
4- Import was successful.
Now the weird issue is that if I open the table through either SQL or directly from the AOT, the data is there! However, when I go the EmplTable form and I click in my custom button (Menu Item Button - Menu Item Button links to the new form I created and it has the correct data sources) the form is EMPTY!!!
I have already synchronize the tables. I even restarted the AOS and SQL Server services.
I’m clueless … : ( Help please.
