I am looking for the best way to import existing data from Data Pro into Navision 2.00C. Can anyone head me in the right direction? Data Pro creates a standard dBase IV or FoxPro compatible file structure.
Hi, I can recommend opening this file with MS Excel, deleting headers and deleting all “in data Then SaveAs CSV file. You can import CSV file with standard Navision dataport options. If you want import complex data it can be useful if you will create new table in Navision with the same fields as in your database. Import data into these new tables. Then you can transfer this data to the Navision standard tables using batch jobs. If you need to import document history from previous periods you should create and then post documents in Navision. Valentin Gvozdev BMI Inc.
