Importing and Exporting of XPO's from one Layer to other.
Hi Guys,
I am Santhosh Kumar Desai , new to Dynamics AX , I have a query, please clarify it.
If I customize some form in VAR Layer, and I will import the XPO file into USR Layer so what would be the action? So which modifications get affected on user layer.
If I do from USR to VAR so what would be the answer?
Thanks in Advance…
Check below link.
http://msdn.microsoft.com/en-us/library/aa641780(v=ax.50).aspx
http://community.dynamics.com/product/ax/f/33/p/93194/176015.aspx
This is just example.
your VAR modifications will be override and USR modifications will be execute…
if you have any modifications in USR layer apart from the VAR layer,those USR layer level modification will work but not VAR layer’s modifications…
