I’m trying to import xml file into Sales Invoice header & sales invoice Line i.e Table Sales header & Sales Line.
the xml file contains sales header & sales line, in sales line, Item No, Description & cross reference no is given.
If the Xml file does contain the Item No i.e “No.” & its having Item Cross reference No, it should go Item Cross reference No and fetch the Item No. i.e my requirement.
but the probem is that Xml file contains Item No. = 0 (integer 0) & if try to import that file, it is not reading the last line of xml file which contain Item No. =0.
here is the code written on
No - Import::OnAfterAssignField()
IF “”.“No.” =format(0) THEN BEGIN
CrossReference.SETRANGE(“Cross-Reference No.”,Cross_Reference_No);
IF CrossReference.FINDFIRST THEN
“”.“No.” :=CrossReference.“Item No.”;
end;
I’m not getting any clue how to read the sales line of xml file whihc contains Item No is equal to 0(zero), becasue Item No field type is code.
Would you please help out.
Regards
Pushpraj
Regards
Pushpraj
