Import v2009 Fob to v2013
hey Floks ,
I’m not able to import a fob from 2009 into 2013. What would be the workaround if i wanted to move some reports ?
tx,
g.
What is the error ??
It seems you are using importing NAV 2009 object in NAV 2013 R2 developer environment .
You have to import the object in NAV 2013 environment and Build server Application objects .
Post this you export the object from NAV 2013 and then import it into NAV 2013 R2
Did you try these steps ?
  1. export reports in txt format
  2. run TextFormatUpgrade2013 Tool
  3. Import in 2013 database
