Im with basic knowledge of nav development.
I need import physical stock from text file (csv) to phys inventory journal. I have created dp with below fields
“Item No.”
“Qty. (Phys. Inventory)”
- Ill generate phys stock over journal lines and using dp to export as csv.
- Do necessary changes on csv need to import back to journals.
- Post journal
Then I realized that some fields like Quantity, “Invoiced Quantity”,“Quantity (Base)”,“Invoiced Qty. (Base)”,“Entry Type” needs to be changed according to the changes of csv. I tried to trigger those fields with VALIDATE but didn’t work. Afterwords I have included those fields to dp.
When I’m trying to import data Im getting "Item No. ‘’ does not exist. " Seems something to do with line nos and tried few ways but ended up with no luck. Anyone can assist me ?
hi,
i tried following with success using the first row of table 281.
the export dataport:
OBJECT Dataport 50001 Phys. Invent. Export
OBJECT-PROPERTIES
Date=16.11.14;
Time=19:46:29;
Modified=Yes;
Version List=;
PROPERTIES
Import=No;
FileName=c:\temp\phys-invent.csv;
FileFormat=Variable;
FieldSeparator=[;];
DATAITEMS
{ PROPERTIES
DataItemTable=Table281;
ReqFilterFields=Item No.;
FIELDS
{ 1 ; ;"Entry No." }
{ 2 ; ;"Item No." }
{ 3 ; ;"Posting Date" }
{ 4 ; ;"Entry Type" }
{ 5 ; ;"Document No." }
{ 6 ; ;Description }
{ 7 ; ;Quantity }
{ 8 ; ;"Qty. (Phys. Inventory)" }
REQUESTFORM
PROPERTIES
Width=9020;
Height=3410;
CONTROLS
CODE
BEGIN
END.
for import part change the Import property to Yes.
i exported the first row, changed the values for Quantity and “Qty. (Phys. Inventory)” and imported that row again without errors.
