Import product on Data migration framework
i have been trying to import a product list via the data migration frame work.
i have done the following:
  1. create the entity name and select product, when i generate the source file it gave me the following fields as mandatory:
DisplayProductNumber
EcoResProductTranslation_LanguageId
EcoResProductTranslation_Name
ItemId
ProductSubType
ProductType
none of the above files can be unselected.
  1. generate the source file, in the source file
  2. generate the source mapping
  3. validate
  4. i go to the staging data, and everything is fine
  5. copy data to target, here comes the problem, when i run the job, it gives me the following error:
Cannot create a record in Product number (EcoResProductIdentifier). Product number: XXXXXXX.
The record already exists.
when the record is totally new, i did change the item name many times but the same error, actually the error is created from the ItemId field, which i cant ignore.
what should i do?
is there any other field that i have to include in my file?
Regards
Fadi ghrawi
Check this recent post
http://www.fourone.se/blog/2012/11/06/dmf-cannot-create-a-record-in-product-number-ecoresproductidentifier/
Hi munib,
Thanks for the reply i think that my problem was generated because i didnt update my AX kernal version to 6.0.1108.670 and i was using the old one.
now everything seems fine after installing the hotfix.
am not really sure though
Regards
