hello, we have a merged txt file with the changes of our customized version (3.10) and the 3.60 version. we try to import it in a new 3.60 db. we receive the error ‘your program license does not permit you to create the Allow payment tolerance field in the customer table’. We do have a full-license. any idea ? Any help is welcome, thanks in advance.
quote:
Maybe a silly question, but: which number has this Allow payment tolerance field? Anna
the fieldnumber is 116.
If i’m right then you’re upgrading from 3.10 to 3.60. If so you fave to import files not in empty db but in 3.60 db with standard objects. It should work.
thanks arthur that was our problem. it now seems to work. thx.
