Hi, When I export a table-object in textformat and immediatly want to import it again, I receive the error message “t_id is expected here” and then “import stopped at line 102”. I don’t see any incorrect data at line 102 of my textfile. It concerns the declaration of the variables. Any idea ? Greetzz Steve
Is the table that you want to export compiled? Anolis Sittard Netherlands
Yep it was compiled
Is the CSIDE engine/database that you’re trying to import the text file into of the exact same version as the CSIDE engine/database you’re exported the file from? Best regards, Erik P. Ernst, webmaster
Ideas… Something is “inconsistent”… on line 101/102. Don’you see a special character like { } < > [ ] ’ " …etc. Check also if your don’t have a blank function name… Which Navision version is it ? Post a few lines around lines 101/102. Hope it helps. Louis
I’ve compared the file with a text file that works fine, and I see no difference. So I don’t think that this is the problem. I use Navision Attain 3.01A Thx
